2005-07-20 12:36 PM
2005-07-21 01:51 AM
2005-07-21 11:30 AM
2005-07-22 08:03 PM
2005-07-22 09:00 PM
Karl wrote:That's the ticket Karl! If you switch to DETAILED 2d VIEW you will see the "project2" version of the real tiles in plan.... Here you can insure they line up together...
Sounds like the problem is resolved ... but, without time myself to test at the moment, I wonder if it is really the lower left corner that is the alignment? Duane Valencia has reported his tip on aligning standing seam metal (same roof accessory) several times, where, if I recall correctly, his solution was to assure that the centers of the roof pivot lines matched ... or maybe the roof pivot lines themselves had to be the same length and aligned...?
2005-07-22 10:08 PM
2005-07-22 10:18 PM
2005-07-22 11:58 PM
2005-07-23 12:23 AM
2005-07-23 04:09 AM
