Jerkin head roof in Archicad 15
Hi all,
I'm trying to make a jerkin head roof in AC15. I've found a tutorial on youtube (http://youtu.be/dguAopDgmMs) and it's exactly the roof i want. It is without sound though, so i'm stuck near 2:48 where they are extending/connecting the ridges of the roof automatically. I tried holding ctrl or spacebar, but i can't seem to extend the ridges of the large planes to the ridges of the small triangle planes.
I've managed to move the triangle planes but in the end i get the following:
The eaves? (don't know if that's the correct english term) don't connect fluently.
In the youtube-movie the eaves connect perfectly.
Does somebody knows what shortcut the youtube-poster is using or what i do wrong?
thanks.
1 REPLY 1
David Maudlin
Rasmazzer:
The tutorial is done with ArchiCAD 14 or earlier, you can tell by looking at the Geometry Methods for the Roof Tool (at 0:25) and seeing the Dome option, which was eliminated in ArchiCAD 15 (also, the video was posted in 2008). It is a bit confusing, as the PolyRoof Geometry Method icon in 14 is the same as the Multi-plane Roof icon in 15. So the Roof is composed of single plane roofs, which can be connected as shown using Command-Click (on Mac) or Control-Click (On Windows); in the AC 15 Help files see: Virtual Building > Construction Elements > Roofs > Editing Roofs > Intersect Single-plane Roofs.
I was able to create the roof you show by using the Multi-plane Geometry Method with the Rectangular Hip/Gable Construction Method and stretching the perimeter back into the roof.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
