Joining walls
Virtual Tutor 10 shows a technique to cause 2 walls to join (select one wall, hold command key on Mac down, left click the other wall). I do not find it works in 11 - how do I get walls to join?
It sounds like you are referring to "Adjust" -- you must have the Wall tool active (to adjust wall elements) -- select object to adjust, command + click on the wall with which you want it to meet.
Yes, it is a tricky one because CTRL-clicking is also used for Trimming.
It DOES matter what Tool is active.
