We value your input!
Key conflict - Running Archicad and Risa on a MAC-
MacBook Pro OSX 4.9 and Win XP on Parallels
I have installed Risa 3d in XP.
Risa is protected with a Sentinel Pro with driver 7.4.0.
Both Sentinel Keys are plugged in at the same time.
If Risa is running Archicad 10 does not find its Key, the message is “Protection Key missing”. Risa has no problem with Archicad’s key.
I have Called Safenet TS. They said Graphisoft did not implement the APIs correctly, There are two APIs: Find First and Find Next.
Has any of you a solution for this, is it possible to run these programs at the same time each with his own sentinel key.
Thanks in advance for any suggestion
I have to restate the problem:
Running Archcad and Risa on MAC- key conflict
Both the Sentinel Keys and the Archicad Wibu key are plugged in at the same time.
If Risa is running Archicad 10 does not find its Key, the message is “Protection Key missing”. Risa had no problem with Archicad’s key until I have installed the Wibu driver on the XP. There after the Wibu driver cancels the Sentinel so Risa does not find its key. Reinstalling the Sentinel key fixes the problem until one runns Archicad. To runn Archicad ome must remove the Sentinel Key.
It is a mess.
I gave up on Paralles & Cross Over running Risa-3D. Paralles & Cross Over do not support USB Keys, their representatives informed me. I use BootCamp & IFC to go between Risa-3D (in weeks coming) & AC.
Joseph
I have news for you, Parallels and Risa works perfectly the problem is a Wibu and Sentinel conflict with or without Parallels.
