MacBook Pro OSX 4.9 and Win XP on Parallels
I have installed Risa 3d in XP.
Risa is protected with a Sentinel Pro with driver 7.4.0.
Both Sentinel Keys are plugged in at the same time.
If Risa is running Archicad 10 does not find its Key, the message is āProtection Key missingā. Risa has no problem with Archicadās key.
I have Called Safenet TS. They said Graphisoft did not implement the APIs correctly, There are two APIs: Find First and Find Next.
Has any of you a solution for this, is it possible to run these programs at the same time each with his own sentinel key.
Thanks in advance for any suggestion
