LINES END TIPS
Is it possible to ad a line tip to ArchiCAD. What I refer as line tips, are those things you can add to a line when drawing it that is below the line type, like little circles, arrows, etc. That one can also define pen color for it. I use normally something that I created as an object but is not very useful for example when specifying construction documents, etc. And ArchiCAD's own are not very nice, are too simple. Can anyone help?
I work on AC 8.1 an a MAC under OSX panther
2 REPLIES 2
You can put arrowheads, dots, etc. on one or both ends of any line, circle, etc.
The setting is in both the info palette and the settings dialog.
Thanks Mathew for your reply but what I meant was if one can add more kinds of line ends than those that archicad has on its original programing. Do you know how to do that?
