Lat Long values as autotext
Hello,
can anyone tell me if its possible to access the lat long values set in Project Location so they autofill in a text block or title block?
cheers, Hugh.
3 REPLIES 3
Not as autotext but you do have GLOBAL variables in GDL.
GLOB_PROJECT_LONGITUDE project longitude (project dependent, do not use in parameter script)
GLOB_PROJECT_LATITUDE project latitude (project dependent, do not use in parameter script)
GLOB_PROJECT_ALTITUDE project altitude (project dependent, do not use in parameter script)
the geographical coordinates of the project origin according to the settings specified in the Project Location dialog
aaargh GDL!
thanks Barry, maybe one night when i'm feeling brave enough to open the gdl books...
hugh
I just found the AC 20 object called "Coordinate Dimension 20"
which does just this- I'm so happy!
Hugh
