If your column and beam are in the same layer and that layer has an intersection number greater or equal to one then then the strength of your Building Materials come into play - the stronger material will cut the weaker one (Legacy mode must be turned off for this to happen). If both are equal strength I believe Archicad will still make one cut the other.
If the layer intersection number is zero then there will be no automatic intersections.
If they are in different layers then if the intersection number is the same for both layers they will cut each other based on BM strength.
If both layers have different numbers (or one or both are zero) then they won't cut each other.
Of course you can still do Solid Element Operations regardless of the layer intersection number so you can still control the cuts if you still need them when they are not automatic.
