2006-01-04 03:36 PM - last edited on 2023-05-26 03:10 PM by Rubia Torres
2006-01-04 04:08 PM
2006-01-04 04:30 PM
TomWaltz wrote:Tom, thank you for the 3DS export tip...yes, by being able to define layers by materials would do the trick. I used the DWG translator.
Which renderer are you using and which export method are you using from Archicad?
I believe the 3DS export allows you to define layers by material instead of Archicad layer, which would get the effect you are aftecr.
2006-01-04 04:49 PM
2006-01-04 07:22 PM
2006-01-04 07:30 PM
Josephus wrote:From the sound of it, you are gettng the same benefit from FormZ that we are from C4D. Basically better rendering and the ability to add in things that Archicad has a hard time with.
One advantage of being able to import into FormZ is that we can add some 3D detail that is MUCH easier to do in FZ and add all the trees, cars, people, etc. The Lightworks rendering engine inside FormZ Renderzone seems to work a LOT better than inside AC. I'm not familiar w/Cinema 4D but have heard some about it. Once Maxwell is up and running, we'll do all our better renderings there (hopefully they have achieved the 1000% speed increase they were talking about). In the meantime we'll use the FormZ Renderzone rendering engine.
2006-01-05 04:17 AM
