Layout
How can I Place this view on a layout.???
4 Replies 4
You can right click on the view in the View Map (Navigator) and select "Place on Layout", but it is generally best to use the organizer to drag views from the onto the layouts.
This is very basic stuff. You should really take some time with a tutorial, get some training, or find some local users to talk to.
Eduardo Rolon
Already answered on the other post. Please DO NOT Double post.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
But when I want to have JPEG format from It.its in low resloution,How can i get It High quality????
Save the layout as a PDF, then open the PDF in Photoshop. It will give you the option of defining the dpi level (dots per inch) of the conversion. Try setting it to 200 dpi and see how it looks. Now you can save it as a JPEG.
