Leaning forward Wall
HI there can anyone show me how to do a leaning walls? i cannot find angel option in the tool setting dialog thanks. By the way the wall should look like this in side evelevation / <<=== hihihi. Hope you know what i mean.
lovetrain
11 REPLIES 11
Dwight
Tilted walls can be easily made using the Solid Element Operation using a matching pair of roof planes to do the cuts.
One roof cuts with upward extrusion, the other with downward extrusion.
see illustration.
Dwight Atkinson
Dwight
And I meant to add :
"people all over the world, get on board..."
Dwight
Dwight Atkinson
lovetrain
I would like to take the opportunity to advise you of a simpler (but more espensive) object I created . 'Sculptwall-slope' available on Objects Online. It functions like a window but shapes the profile of the wall instead of cutting windows. Other similar objects step/groove/taper the wall.
All the best.
Thankyou for yours help
lovetrain
Dwight
Please post an example of what you finally did.
…join hands…
Dwight Atkinson
rm
OK Dwight,
That was a good first trick......now for your next performance, can you put any and all windows in that tilted wall.
......drum roll please!
Architects Design Forum, Ltd.
Robert Mariani
Robert Mariani
MARIANI design studio, PLLC
www.robertmariani.com
Mac OSX 13.1
AC 24 / 25 / 26
Dwight
I don't know about all windows - in fact, to answer the original tilt wall question, I experimented - to my joy it works. Since I am doing a theatre in Denmark right now, I am using this feature to make tilted stone walls - with windoz, it was a great discovery.
At any rate, you want to be careful about controlling the depth of the frames.
Dwight Atkinson
Aussie John
regarding windows in the roof type wall, I thought at first you might be able to turn a window into a roof light (open the window and save with roof light subtype) you could put a window in the sloping wall (nee roof) but it didnt work. I am sure with some appropriate rotations it could work. Maybe someone with some experience of scripting roof lights might be able to help
Cheers John
[/size]
Dwight
What is the problem with velux or other roof windows?
I do not use them because it rains so much here.
Dwight Atkinson
