Too Long
Legacy Preference
Hi guys.
I work it a small business whos archicad template was built in AC13 and never developed for the following releases but rather just opened in the new version of archicad and saved.
The issue I have is with the Legacy feature.
When the legacy feature is on the beams dont intersect correctly.
When turning off the legacy feature the beams work correctly but all of the walls disappear in elevation.
Can anyone tell me why and how to fix this please?
Thanks.
AC26 AUS Full
22 Replies 22
Too Long
We're so close I can almost taste it but that didnt work for me.
But I uploaded the repair file. Would you mind checking if it works for you please?
Thanks for all your help.
https://www.dropbox.com/sh/ew62ltngs2l4ove/AACgt-l0oULWlahs3LTV3iFVa?dl=0
AC26 AUS Full
Yep, worked perfectly for me, except I don't have the 4D library.
I opened it in 23, is that the version you are using?
Too Long
Yep 23.
Weird.....
It wouldnt be the library would it?
AC26 AUS Full
Too Long
So the wall are there just not visible, as in o outlines like you said.
AC26 AUS Full
That last file you sent (7234KB) opened fine for me.
It shouldn't have anything to do with the library.
Make sure you have the latest build for 23 (4006).
Maybe shut Archicad down and reopen the file you just sent.
Too Long
Hmmm...
I restarted the machine and still nothing.
Ive even used a complex profile to see if that work and nada.
AC26 AUS Full
Are you sure you are opening the repaired file?
Maybe try the repair again.
As soon as I did the repair, got the message something was fixed, the elevation was fine.
https://www.dropbox.com/s/splgf0g693s77k9/Template%20Legacy%20-%20returned.pln?dl=0
Here is the file you sent, I have re-saved it.
Too Long
Yours worked perfectly...Thanks.
I did open the repaired file because I saved-as when prompted.
i even repaired the repaired file and still nothing but yours is working perfectly.
Now to see if I can get the template to work.
Thanks Barry, outstanding effort.
AC26 AUS Full
Liamthanks
Hi there.
Just wondering if you ever solved this issue?
I am doing some drawings for a company and they use Version 20 however still had the legacy settings turned om, which was a pain to deal with due to all the lines that appear on elevation.
I have turned off all the settings and am now having the same issues as yourself. Also with the roof planes on plan view - they just don't show, however the roof can still be selected.
Very frustrating, so would love to know how to rectify this in the interim until the company moves to 24.
Thanks.
AC27 Build 5060 AUS - Windows 10 Pro, Ryzen 7 5800X, RTX 3090, M.2 NVME 0.5TB SSD, 32GB RAM
Did you try the file repair option?
That is what worked when I tried.
