Level Dimensions
I would like to show spot elevations of ceiling slabs on my RCP's. When I use the level dimensioning tool it gives me a dimension to the top of the ceiling slab (i.e. 9'-1"). The ceiling elevation should be 9'-0". This slab is also linked in sections correctly. It seems that I need to change a level dimension setting somewhere that dimensions to the bottom of the slab instead of the top? Any suggestions would be great?
Thanks,
Brian
11 REPLIES 11
Llian
Here's another screen shot of my graphisoft folder- archicad library...
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
Srinivas
You need to load the library part into your project.
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
