Level Dimensions
I would like to show spot elevations of ceiling slabs on my RCP's. When I use the level dimensioning tool it gives me a dimension to the top of the ceiling slab (i.e. 9'-1"). The ceiling elevation should be 9'-0". This slab is also linked in sections correctly. It seems that I need to change a level dimension setting somewhere that dimensions to the bottom of the slab instead of the top? Any suggestions would be great?
Thanks,
Brian
11 REPLIES 11
Llian
Here's another screen shot of my graphisoft folder- archicad library...
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
Srinivas
You need to load the library part into your project.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
