Light and heavy floor slabs
KeesW
I've drawn a section through a building including 2 floor slabs, They were drawn at the same time, using the same settings, lines, etc. Yet one is heavy and the other is light. Why?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
1 REPLY 1
This probably is not the answer, but is the light slab actually slightly behind the section line, and is therefore not actually getting cut?
Or is there some other element (another slab or a beam or wall - could be in a hidden layer) that is automatically trimming the slab away?
Actually I think that will be it.
I just tested 2 slabs in the same place and in section you do not see the perimeter lines of the cut slabs.
