Question about a door reveal
How I make this door reveal seamless? The point is I cannot do it through the door settings and the only way I came up with is to do it by adding extra walls but since it's a door opening the extra pieces of wall cannot be intersected seamlessly.
4 REPLIES 4
Hello anto_bg,
Did you try to use bash option into door parameters ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Hello Christophe,
I tried but it can be applied to the other side of the wall only (next to the door). ¯\_(ツ)_/¯ There is an arch in front of the door that I need to show in 2D in some way. The door itself opens inwards because it is a century-old house and we cannot change it.
You are able to put two doors at the same place.
Christophe - FRANCE
Actually I managed to do it by adding the door once again to the wall but this time - in the opposite direction. I set the reveal and then I flipped the door. Luckily the reveal remained where it was.
