Lines don't show in 3D
I have a 3D view and the line at the intersection of the wall and footing appears intermittently. The walls and footing are different materials but are part of a complex profile. All the wall/ftgs are the same profile. Any explanation out there for this?
KrisM
Miha_M
Maybe the lower edge of the wall doesn't match the upper edge of the footing?
| Archicad 4.5 - 29
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
Miha_M
Sorry, I guess I didn't read your post properly. If the whole wall+footing system are one single profiled element then my suggestion is probably wrong.
If the lines do show on the same profile used in one position and don't show in another, than something doesn't work as it should, but I have no clue why.
| Archicad 4.5 - 29
