Lines in Elevation
Hi!
In my interior elevation I see a vertical line between 2 equal an allineate walls.Even when split a wall in 2 I have the same problem.
Please how can make this line disappear?
Thanks
Hi Giuseppe,
Two identical walls with the same material whose hotspots touch should join invisibly in elevation. The vertical line appears when you try and join a third wall in the same place. This thread has a solution -
http://archicad-talk.graphisoft.com/viewtopic.php?t=28985
In the 3d window and in 3d documents these lines between two walls are unfortunately always visible regardless of the settings.
Thanks
