‎2005-11-04 11:50 AM
‎2013-09-10 08:42 AM
‎2013-09-10 05:32 PM
‎2013-09-10 06:05 PM
‎2018-02-12 01:07 PM
Barry wrote:Now it is 2018 now. Can this method using to draw property line as dashed line style?
You could always try a zero height wall where the wall thickness is the width of the line you want (allowing for scale of course).
Drawing a wall in plan is the same steps as drawing a line and one advantage over lines is you can adjust the reference line so it is at the edge or in the centre.
‎2018-02-13 02:02 AM
William wrote:I am afraid nothing has changed.
‎2018-02-24 01:54 AM
‎2018-02-26 03:32 AM
William wrote:No corners aren't so good.
But that method will cause a problem on the corner of lines, not sharp clean corner. Anyway, Thank you very much!
‎2018-03-09 04:12 AM
‎2021-10-07 05:23 AM
I am so glad to find people who really care about how a line ends...Bless you folk!
‎2021-10-07 05:45 AM
@William Yan wrote:
BUt zero height wall can't draw dashed line.
Seems I never replied to this.
They can if you set their 'Floor Plan Display' to 'Overhead' and the overhead line type is set to a dashed line.
