2008-01-30 06:47 PM - last edited on 2023-05-26 12:51 PM by Rubia Torres
2008-01-31 03:27 AM
TomWaltz wrote:
If the floor to floor height is the only difference, you could make the columns the tallest height them SEO them as needed on each floor.
2008-01-31 03:31 AM
Matthew wrote:I'm just "having you on" since in my first posting i suggested grouping.Dwight wrote:Yup.
Like in 3D? Maybe make the columns on a dedicated layer and show them alone in 3D and group individual column stacks?
Columns are usually on the A-COLS, S-COLS or such anyway. It's easy, but it's not a trick😉 (New to 11 though.)
The module approach seems too tedious unless the extra security is important.
2008-01-31 03:32 AM
Dwight wrote:oh I hadn't noticedMatthew wrote:I'm just "having you on" since in my first posting i suggested grouping.Dwight wrote:Yup.
2008-01-31 05:14 AM
Dwight wrote:I didn't realize multi-story grouping had been added to 11. Cool. Works well, and easiest solution.
Group in 3D, either as vertical groups or whatever....
When you move a column on one storey, the grouped ones on other storeys will also move.
2008-01-31 08:59 PM
Karl wrote:Unless you use a multi-story module.
A hotlinked module . . . has the disadvantage Dwight mentions of different story heights, but also that the column members would be the same in each story.
2008-01-31 09:04 PM
2008-01-31 09:14 PM
2008-01-31 09:17 PM
Dwight wrote:Two ways.
How would that be done? I am not familiar with modules.
2008-01-31 09:24 PM
2008-01-31 10:16 PM
Dwight wrote:Just the extra security that columns cannot be inadvertently moved. No big deal since the elements can be locked as well as the layer if desired. It's hard to imagine a need for it in this case. On the other hand I am using modules for the column
What are the advantages beyond simple grouping?
