‎2009-04-13 02:27 AM
‎2009-04-13 02:30 AM
‎2009-04-13 02:48 AM
‎2009-04-13 02:57 AM
‎2009-04-13 03:46 AM
‎2009-04-13 05:28 PM
JLKilgore wrote:Placement Support/Info for ArchiCAD users has always been limited.
Is there anywhere someone can look to see the firms that use ArchiCAD so you can apply or submit resumes to the correct people? I live in Nashville TN...
‎2009-04-13 05:32 PM
‎2009-04-13 05:53 PM
JLKilgore wrote:Yes sir I do, I hope everyone is doing well. PM me with some contact info and I'll get in touch with some ideas about how you can venture out within your local area.
...Remember me from SLC a few years back? Me, Scott Riggle and Rob Burkhart? Let's not forget David Larrew...
‎2009-06-26 10:15 AM
‎2009-06-26 11:58 AM
nats wrote:good luck again and foremost, do not listen to this expert troll
I think you are being a bit naive if you think you can pick a job by choosing a firm that uses only a certain type of CAD software.
To stand any chance of getting a job you need to be flexible and that means being able to certainly use Autocad, Revit, possibly also Microstation, but Archicad is a very low on that list. Autocad is the tool of choice for most and will remain so for the foreseeable future especially with the persent economic climate.
If you want to do fancy images learn 3ds Max. If you want to get a job as an architect you need to use Autocad full stop. Archicad is interesting distration but you wont get a job with a firm that uses it. I have worked for about 15 firms in my time and of those one used Archicad (but not the 3d bits), 1 used Microstation, all the rest used 2d Autocad. Admittedly things are changing a little bit lover the last few years but I have little evidence many firms at all use either Revit or Archicad despite what the salespeople would like to think. If you want to get into BIM modelling Revit would be a far better choice but BIM is still being used minimally in architecture today.
Do yourself a favour, learn 3dsMax, do some fancy images for your portfolio, learn Autocad, and take a project management course and you will find a job quick enough.
