2004-04-30 07:06 PM
2004-04-30 07:42 PM
2004-04-30 07:48 PM
Link wrote:Link,
Z?
Link.
2004-04-30 07:58 PM
2004-04-30 08:13 PM
Link wrote:Now we are talking! I want to get the same functionality that we have in 2D by using Option(alt)+x or y. To start that little dot moving with out drawing a wall (slab, roof...) or after I have drawn the wall to match the height with a remote element hot spot.
Hmmmmmm - I'm not sure. Can't you just hit the z key and enter a z value?
Link.
2004-05-02 11:29 PM
Joseph wrote:I think this is not possible like that. The reason is probably the 3D Window element creation philosophy of ArchiCAD. For each construction element you set its Z height in its Settings Dialog or the Info Box. When drawing in 3D, ArchiCAD will create the element on that plane in that Z height. After creating the element, you may select it and move it vertically (by chossing the appropriate icon on its pet palette) and you can snap to a node of another element to align with it.Link wrote:Now we are talking! I want to get the same functionality that we have in 2D by using Option(alt)+x or y. To start that little dot moving with out drawing a wall (slab, roof...) or after I have drawn the wall to match the height with a remote element hot spot.
Link.
Joseph
2004-05-03 12:47 AM
2004-05-03 08:38 AM
