Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Locking the Z coordinate in 3D
Is it possible to lock the Z coordinate in 3D with a similar key combination like: Option + x or Option + y?
Thanks,
Joseph Harouni
7 REPLIES 7
Link
Z?
Link.
Link wrote:
Z?
Link.
Link,
I do not get it, you mean z + ? or you do not understand my question?
Thanks,
Link
Hmmmmmm - I'm not sure. Can't you just hit the z key and enter a z value?
Link.
Link.
Now we are talking! I want to get the same functionality that we have in 2D by using Option(alt)+x or y. To start that little dot moving with out drawing a wall (slab, roof...) or after I have drawn the wall to match the height with a remote element hot spot.
Joseph
Joseph wrote:
Link.
Joseph
I think this is not possible like that. The reason is probably the 3D Window element creation philosophy of ArchiCAD. For each construction element you set its Z height in its Settings Dialog or the Info Box. When drawing in 3D, ArchiCAD will create the element on that plane in that Z height. After creating the element, you may select it and move it vertically (by chossing the appropriate icon on its pet palette) and you can snap to a node of another element to align with it.
Laszlo
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
A simple workaround to lock, in some way the Z level, is to move the user origin to the desired z level, than you can insert the object which will inherit that level.
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Petros Ioannou
.....or use reference levels (Options/Preferences/Working units & Levels etc)
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
