Longhorn and Archi CAD 10 and Light works and Artlantis R.
I am very confused, with my hardware and sotware...
What can we expect from AC 10?
Supergraphicpower over Artlantis R? (Shall I wait to buy something?)
New Layoutsystem?
What happen with Light work (it has disapointed me...very difficult tu use... but strong lendering....in the future will be better?)
No hardwareproblem with Longhorn?
Please give some tipps!!!
19 Replies 19
Dwight
See "LightWorks in ArchiCAD"
Page 9:
What You Can Expect for Image Quality:
"… as good as possible 'under the circumstances.'"
Dwight Atkinson
Page 9:
This is why Dwight's books (seminars, etc.) are so good. They are about what is actually possible to accomplish in a realistic amount of time within the limits of the available tools.
The question is:
Do you want to make architecture or do you want to be a 3d rendering pro????....
I never understand why people who's job is doing architecture think that they can be for instance a pro rendering designer...
If you bought ArchiCAD to be architect...GREAT.....you bought the right tool......BUT you want to make renderings????? real renderings?? .....it means that you can't be architect anymore because these kind of job is for professionals of that area....not a project maker...
Don't ask for better rendering tools in ArchiCAD...These tools already exists for years in especif softwares..
stefan
I disagree here. When you are an architect, you have the right to make the renderings yourself. You are not competing here with fulltime visualization artists: you are promoting your own design. LightWorks is precisely at the right place: integrated and powerfull enough.
I would be glad with added radiosity and more direct control over materials in a modeless dialog instead of opening several dialogs, closing them, rendering, reopening them again etc...
And if you want to go the extra mile, you can outsource it or buy a professional application that does it better (at the cost of conversion).
Archicad-user since 1998
my Archicad Book
I just finished a big project for the first time in AC (till now I did autocad/3d max combination). AC is a wonderful program that speeds up drawing like doors and windows, sections, elevation... Only thing I did in Autocad was site plans.
I missed radiosity in renderings. Renderings are fast but the price is 2nd class visualization. When finished with drawing, for visualization with very high resolution photos I usually set up all cameras and views for rendering and leave computer over night to do the job, so a slow but quality radiosity option would be very usefull for me so I could present my work much better.
One part of architects job is presentation. We have to show the building before it is finished and too late for modifications, so, better renderings - better presentation.
i need a program to create the light instalation to a bildin can you help me ples. Darckman@yahoo.com
Dwight
Okay.
Neither Lighworks nor Artlantis produce a technically accurate light scheme for a building where lamp engineering values can be emulated.
LightWorks requires a photographer's approach to lighting space, where a few general lights provide strong ambience and soft shadows.
Artlantis can actually render dozens of light sources efficiently, but adjusting them proves time consuming.
Dwight Atkinson
stefan
Then you should take a look at Physically correct renderers with support for falsecolor images:
Radiance http://radsite.lbl.gov/radiance/ (free and open source)
Autodesk VIZ/3ds max http://www.autodesk.com/viz
Integra Inspirer http://www.integra.co.jp/
Autodesk Lightscape (not available anymore)
Relux Professional http://www.relux.biz/ (free)
etc...
my Archicad Book
Informations I'm about to write are not confirmed. I found them on polish archicad forum and they're just some first impresions from beta version of AC 10. Like below:
- Plotmaker will be finally soak into ArchiCAD, you'll be able to use it via project navigator, also you can assign different pen sets to different layouts
- coordinates and control bars will be convert to a kind of pet palette which follow cursor, so you'll have it always at hand
- there will be "mesuring tape" tool for easy mesure of distance between any two points
- menu options were reorganized, for example "display options" has its own preview window so you can see how your configuration will affect the plan
- you can finally do sloped walls and posts without gdl script, also bottom and top thickness of a wall can be different
- fills can use gradients now (linear or radial)
- fills have their own X Y axis and can be resized independently (you can change proportion of a pattern) and what is more - bend them
- "see what you're about to select" function, cursor recognize what is under it in 2D and 3D
- one navigation orbit in 3D!! shift+mouse for navigation instead of previous 3D navigation palette
- Lightworks environment seems not to have any major improvements
The same lousy material preview window, no radiosity.
Looks like they focused on some long-time-needed improvements more than on making revolutionary release.
Eduardo Rolon
and if true it sounds as if AC is following Revit...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
