‎2021-09-28 01:00 PM
A generic beam/wall/morph-like tool that have different lines on the sides as shown in plan attach. It's for curbs'n'stuff. Anyone?
/M
‎2021-09-28 02:56 PM
I use this. I calculated material start points too so they follow the curve.
‎2021-09-28 04:23 PM - edited ‎2021-09-28 04:26 PM
How does it show in the plan view? I think I've tried this object sometime. Is it possible to download and test it?
‎2021-09-28 09:48 PM
it will show each point of the profile poly line as a line in plan view.
It does not allow for different line types but this can be achieved easily with a simple algorithm.
‎2021-09-29 07:47 PM
Just figured out how to add custom profiles so I'll update you once I have it loaded into this object
‎2021-09-29 08:50 PM
Hmmm...it doesn't show up with the object tool!? I've loaded the objects as embedded but can't find the anywhere. Are thy working with another tool?
‎2021-09-29 09:53 PM
Load the whole folder not just the objects.
And I don't ever embed anything so I can't say it'll that's causing an issue.
I can make it an lcf if that helps but really shouldn't matter
‎2021-09-30 05:15 PM
I'm honestly not sure how it was working for me but I am pretty sure it will work now if you redownload it
