Lost Perspective view setting
When I go into the 3d model, the orthographic view setting works fine, but the perspective view setting will not show my model. its as if its lost floating in space somewhere. Is there a reset command for the perspective view setting to get it back?
Any help would be much appreciated..
3 Replies 3
Hi Andrew
Welcome to the Forum
This issue has been discussed lots of times on the forum, including HERE.
Tip 1 - try the search button at the top to see if things have been discussed before.
Tip 2 - add your ACversion and OS to your signature (in profile) so Djordje doesn't pull another hair out.
Open your 3D projection settings window.
Ctrl-click to set a new point of interest and alt-click to set a new location for the camera.
This should solve it...
Djordje
Yeah, I am moonlighting as a cue ball ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
