MEP Pipe modelling for drainage
RJSNZ
Is there a good process to use the MEP tool for modelling drains with minimum falls for horizontal runs?
The only solution so far is you to grab and adjust every node individually after separately calculating a height adjustment.
Also the Route Specifications seem to only have SS pipes, Copper, Carbon Steel and Composite. I thought that PVCu was a common product in construction.
Before I build my own table of dimensions if there a resource for this already?
Operating system used: Windows 10
0 REPLIES 0
Setup info provided by author
