russfairhurst
MEP pipe branch size
I am trying to model 100mm stormwater pipes into a project. Have set the route specifications for 100mm PVC pipe. When I join pipe the pipe branch is always being created as a 75mm. I select it and the size is greyed out so can not be changed. Have tried having pipe branch set at 100mm before making the connection but it keeps changing to 75mm. It does this if the pipe is smaller as well. Any ideas?
Cheers Russ
Versions 6.5 to 28
Windows 11 Intel Core i9-13900K RAM 128GB NVIDIA GeForce RTX 4090
0 Replies 0
