2026-01-13 07:43 PM
In a piping ssystem can be more than one systems conected? example:residual piping and ventilation piping
Solved! Go to Solution.
2026-01-13
08:15 PM
- last edited on
2026-01-19
11:18 AM
by
i do it with a 3 option, with an custom id for the ventilation pipe and graphic override, but only paint the label not the pipe
2026-01-13 07:47 PM
there are 2 options
1. Create an object that has 2 connections where you can set the MEP system. Then you can connect the routes to it
This object can be created from 2 MEP connections and then saved as a new MEP object
2. If you don't care about imperfection, you can just leave a small gap between them (0,1 units)
2026-01-13
08:15 PM
- last edited on
2026-01-19
11:18 AM
by
2026-01-16
06:50 PM
- last edited on
2026-01-19
11:19 AM
by
Hello
is there an object like this for mep 29?
2026-01-19 02:25 PM
There is a flexible pipe tool with which you should be able to do this. A bit clumsy, not as intuitive like the versatile MEP library
2026-01-20 12:24 PM
Hello Karel , thank you i will try
