Learn more
MESH FACADE??? IS IT POSSIBLE?
Hi
Is it possible to create a facade using mesh?? Trying to recreate the facade shown in the photo since I used morphs for that one which is problematic in plans and section drawings.
1 Solution
Erwin Edel
You could 'trace over' those morphs/meshes segments with curtain wall tool in 3D to get you close to what you want, I would say. Each segment would be an individual curtain wall. If you put these on projected rather than symbolic, your floorplan display should be correct.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Go to post
3 Replies 3
Erwin Edel
www.leloup.nl
It seems to be working so far! But how to I change the setting to projected rather than symbolic? Also, is it possible to change the settings so theres no frames inside the curtain wall so I can paint it over with a different surface?
Thanks for your help!
Ernest Atanasiu
I suggest you get acquainted with the Curtain Wall tool first through tutorials and help menu.
no frames = select frames and make them invisible
projected/symbolic = "Floor plan and Section" in Settings Dialog.
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 10/ Win 11
