2018-10-15
		09:48 PM
		2023-05-24
		07:32 PM
			Rubia Torres
Solved! Go to Solution.
2018-10-16 03:50 PM
2018-10-16 03:50 PM
2018-10-17 04:25 AM
Erwin wrote:It seems to be working so far! But how to I change the setting to projected rather than symbolic? Also, is it possible to change the settings so theres no frames inside the curtain wall so I can paint it over with a different surface?
You could 'trace over' those morphs/meshes segments with curtain wall tool in 3D to get you close to what you want, I would say. Each segment would be an individual curtain wall. If you put these on projected rather than symbolic, your floorplan display should be correct.
2018-10-17 09:25 AM
Thanks for your help!
