We value your input!
MORPH Element - Lines in Elevation and 3d
Hi.
MORPH Tool = Awesome
Very powerful.
Baby Steps - Using it to create a few quick stucco details on the fly in 3d.
Problem...
Lines appear at junction of MORPH element and adjacent columns / slabs.
Any ideas?
I have tried changing surface materials. I have tried SEO operations on the MORPH element.
All the nodes are definitely in contact. The lines will just not go away.
I know there are myriad different ways to achieve the arches but wanted to get the MORPH tool working.
Thanks.
18 REPLIES 18
Oh, and co-planar MORPH to MORPH, no mating of surfaces either turns out.
That would make the Morph a Mule (sterile offspring of donkey and horse). 😉
One of the forum moderators
AC 28 USA and earlier   •   macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
g.h.design wrote:
(Except in Lightworks Render)
Not just LW. If you turn "Contours" OFF in the 3D window, then your OpenGL 3D window will not show the lines either.
But, with Sections/Elevations, 3D Documents, etc still being bread-and-butter of construction drawings, this lack of clean-up reduces our abilities to use Morphs for quick model embellishments.
The first time I saw this was with Complex Profiled walls - where I used a Morph to wrap a CP extrusion around a wall end - a half wall that had a cap. So much for the easy solution.
We can only hope that improvements are on the way...
Hah. A Mule
Thanks for the response.
Cheers as well.
maybe a workaround might be to use the morph object as an SEO object on a hidden layer and 'add' it to the wall while retaining wall attributes - haven't tried it, but may be an option.
Nope. No cigar. Just tried it...
Turn everything into morphs and then you can hide the lines.
Reminds me of a Modern English tune.
'I'll stop the world and MORPH with you'
MORPH the world!
Red
Running into the same issues...
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
