‎2006-09-21 10:56 PM
‎2006-09-23 01:49 AM
‎2006-09-23 09:57 PM
‎2006-10-06 01:02 AM
‎2006-10-06 01:08 AM
mark wrote:once you click in a working window? you have 'stick around' turned off! right-click the top of the navigator and deactivate 'auto-hide navigator'
I've found two problems :first the navigator window closes once I start using a tool.
Then, eventually the 3d window begins to leave generated ghost lines; the cursor becomes a dot and it's registration lines no longer appear.which 3D window? internal or openGL? could it be more of a graphics card issue - not normally something that macs get affected with though. what happens if you 'rebuild and regenerate' the 3D window (hold down ALT before invoking the 'rebuild' command).
‎2006-10-19 01:49 AM
~/archiben wrote:mark wrote:once you click in a working window? you have 'stick around' turned off! right-click the top of the navigator and deactivate 'auto-hide navigator'
~/archiben
