Making a roof
I would like to use archicad to create a roof for one of my 3d models (what Can I say... I love the feature of Italian tiles )
Anyway I was able to make a basic roof and all that, but I found a couple of conditions that I couldn't figure out how to make them in Archicad
Here is the first one:
Problem 01
(The picture above is an AutoCAD drawing)
I would like for the roof to die in the wall on the second floor. Perhaps my problem was that I didn't model the walls. (I only model the roof, because that is all that I need)
Problem 02
Problem #2 is pretty similar to #1...
Problem 03
side elevation
I guessing this is the hardest to accomplish. I want an area of the roof to be elevated and then merge with the rest of the roof. Notice that the elevated area (tower) would become the highest point of the roof so the rest of the roof has to follow along on the back :confused:
thanks!
Leo
8 REPLIES 8
For problem 1 and 2
Use poly roof in archicad and delete one part of the roof and modify the others by using pet palette (move node, ofset edge..)
see the jpegs
Pet palatte-modify jpeg
pardom my ignorance.. but how do I delete that piece??
also, I'm looking for pet pallet... but it doesn't show at windows/ pallets
Select the roof, then
Edit-grouping --suspend group (pull down menu) then delete the part.
To see the pet palette , select the part (roof,wall.etc) then click again.
But,
These are the basics of ac, there are alot of things like that so I suggest you to buy a ac book or download some doc.
http://www.graphisoft.com/support/archicad/documentation/.
Thanks! Now I'm getting to something
Who else could help me with this one:
Problem 03
side elevation
do you guys need more pics to make it clear?
thanks!
BTW
The other day I got a copy (1 month free Revit) in a Revit convesion. I was all happy thinking that I could learn Revit or archicad in a few minutes... but it doesn't seem to be the case
leo
Djordje
Get to an Archicad training session soon ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
TomWaltz
It's about as likely as learning architecture in a few minutes...
Tom Waltz
Leo, have you found a solution to your "Problem #3"?
I might have a solution to your problem it's a bit hard to explain using this forum.
