2024 Technology Preview Program
Masonry hatch, non-orthogonal>off-grid walls
Trying to use the material hatch to make the joints in elevations on CMU (concrete block) masonry walls in a building with non-orthogonal (and therefore off-grid) walls, the first problem I find is that the hatch seems to have a single origin for all walls and therefore cannot be adjusted to each off-grid wall.
Because the walls are non-orthogonal and are not always parallel to the section/elevation line, a fill won't do the job either. The model is rather complicated and using 2D lines all over the elevations with walls in any possible angle relative to the section/elevation plane would suck considerably.
I am thinking of attempting a window object to draw the CMUs as 3D lines on the walls. Is there a better way?
__archiben
no - the origin and direction of the vectorial hatching can be set differently for each individual wall. use the 'align 3D texture' commands in your Edit menu . . .
HTH
~/archiben
b e n f r o s t
Ahahah! I had always avoided 3D hatching and never got acquainted with that one. Great. Thanks. I have a lot more weekend ahead of me then.
