Material ID's
In the company that I work, the architecs use archicad and each time they make a new material it ends up as a higher number even though there is lots of spaces free in the lower numbers. Right now we are at ID number 550, so the next material ID will be 551, but material ID number 30-60 is free for use. How do you change the material numbers or make new materials with lower numbers.
This becomes a problem for me because some day because I work in 3ds max and my maximum multimaterial is 999, dont know how far archicad allows the materials ID's to go. Also I think it is a mess with spaces inbetween.
Hope you understand the question.
Jakob
7 Replies 7
Stress Co_
Drag the slider (or type it in the box).
Marc Corney, Architect
Red Canoe Architecture, P. A.
(I think he is talking about ID numbers, not Intersection Priorities)
Stress Co_
s2art wrote:
(I think he is talking about ID numbers, not Intersection Priorities)[/size]
I think your right
Here then:
i thought he might have been talking about the index number in the Attribute manager and referring more about surfaces than building materials (although it is similar for both).
If you delete surfaces, then that will create the gaps in the numbering that was mentioned and creating new surfaces will be added to the end of the list hence 550-551.
I haven't had any issue with the numbering not being sequential, but I suppose you could use the attribute manager to move surfaces back and forth using append or by Index to fill in gaps, but it gets mess as you don't want to overwrite or delete things, plus you have to rename and delete and replace surfaces
Thank you for all your answers.
Yes I think that tiggerF is right, as you can see, im no expert in Archicad, I havent even installed the program on my pc. But the screenshot that you provide looks right to me. I have huge gaps of several hundred empty ID numbers on the materials, so over the range of 550 materials - maybe 200 materials is in use.
David Maudlin
jakobs:
Not easy to do, here is a post with one method: New attributes create with highest index number.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David wrote:
jakobs:
Well this is my first post and it can very well be my last. And as I said, I dont have Archicad installed. But thanks for your link.
