Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
I have a railing with wooden (pine) associated to it in 3D.
Unexpectedly, and shockingly, the material has changed to clear water or glass. see attached.
All settings are still correct.
Mystery ? I cant seem to reset to pine.
Even if i redraw from new - the assigned material is appearing as water(glass as shown.
Look at MVO > Railing Options: if set to Simplified or Schematic, then click the Options... button to set the Surface.
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
