Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Materials not showing true:
I have a railing with wooden (pine) associated to it in 3D.
Unexpectedly, and shockingly, the material has changed to clear water or glass. see attached.
All settings are still correct.
Mystery ? I cant seem to reset to pine.
Even if i redraw from new - the assigned material is appearing as water(glass as shown.
4 REPLIES 4
David Maudlin
atfonit:
Look at MVO > Railing Options: if set to Simplified or Schematic, then click the Options... button to set the Surface.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David thanks.
Signature added - cheers for that.
What is MVO ? THx
atfonit wrote:
What is MVO ? THx
Model View Options.
David Maudlin
atfonit:
As Barry said MVO = Model View Options, and they are saved as part of the View (similar to Layer Combinations, Scale, etc.).
Thanks for adding your Signature.
David
