2006-08-09 08:55 PM
2006-08-11 03:30 PM
2006-08-12 05:14 PM
gergazi wrote:It might depend on your 3D window settings. Try setting it to OpenGL without edges, shadows and transparency. It should work.
I am working on a big project. In 3d window ı can not see my whole poject.(not enogh memory).
2006-08-13 10:28 PM
2006-08-13 11:34 PM
2006-08-14 11:11 AM
2006-08-15 05:32 PM
gergazi wrote:Oh, that is simple. Just look away into the empty space when you open the 3D window. The model will be saved anyway.
I try to get the 3D to save in ATL. So it depend on the real RAM. Navigatin in 3D is not necessary for me. So I use internal engine in wire frame mode which use less RAM than open GL and enough for ARTLANTIS.
Also there is a difference in which GDL object you use. If I use an object in Ac Library I get 5,500,000 polygons. If use my self made object I can get 2,500,000 polygons so I think type of the GDL script affect the calculation and RAM.
