May be a silly question.....
Upon recently opening my ArchiCAD, I noticed that all elements that are set up with no backgrounds (ie: walls, post symbols, etc...) have a slight grey tint to them even though the settings indicate they are supposed to have no background color.
Is there a simple fix or tab or perhaps I accidentally changed a setting unknowingly?
Help!
Thank you in advance for input.
Mike
1 REPLY 1
Eduardo Rolon
Check your Work Environment Settings
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
