Measure tool grayed out
Hi, i am using archicad 13, i also have 9 and when i go to 3D i want to measure the vertical height when i am at side view but the measure tool is grayed out
Can somebody tell me if its possible to use the measure tool in 3D at archicad 13 or 9? If yes then how?
Thanks!
12 REPLIES 12
David Maudlin
fusemkd:
I tried this in AC 13 and the Measure tool works in 3D along as there are points for the tool to respond to on the model (corners, temporary Snap points, etc). I was able to invoke the Measure tool using a keyboard shortcut.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
oh sorry i wrote wrong thing
i was actually asking for the Dimesnion Tool, not measure sorry.
So i wanted to know how can i use that? I'd like to do it on side view to get the vertical heights. And also if possible to be on wireframe mode
The dimension tool is a 2D tool and can not be used in a 3D view.
For the side view you can create an Elevation and dimension in there.
For the wire frame view have a look in your library for a 3D dimension object that you can use and stretch that into place.
Or better still you can create a "3D Document" of your 3D view which you can dimension with the dimension tool.
David Maudlin
fusemkd:
As Barry said, the annotation tools do not work in the 3D Window, but you can create a 3D Document of the 3D view which can use the Dimensioning, Text and other annotation tools. In the Help files see Virtual Building > ArchiCAD Model Views > 3D Document.
Thanks for adding the signature.
David
Is there a way i can change that 3D document into wireframe?
-Thanks!
David Maudlin
fusemkd:
the 3D Document does not have a wireframe mode (it is really a Shaded view, thought there are settings so it appears as Hidden Line). I have 2 workarounds, but each has its flaws:
1. In the 3D Window, set the view to Wireframe, then use the Marquee Tool, Flat Geometry Method, to copy the image. This can be pasted into any drawing window (Plan, Worksheet, etc) and the 2D annotation tools used for dimensions and notes. The downside is that the pasted image is just 2D lines, no longer part of the model, so if the model changes this process will have to be repeated.
2. In the Materials Settings, create a new material that has a Transmittance setting (under Internal Engine: Transparency) of 51 or greater. Assign this material to all of the parts in the 3D Window you want to be wireframe. Create the 3D Document, and in the 3D Document settings, turn on Transparency (under Uncut Elements). The downside to this method is that it changes your material assignments on the model.
Neither is perfect, but one or the other will get the output you need, depending on the trade offs you are willing to make.
David
Thank you very much, it worked!
-Thanks!
Not wire frame as such but you can set the uncut surfaces to have a uniform pen colour and then set that pen colour to a white pen.
You could even use the transparent pen (Ø) if you want.
This will give the illusion of wire frame and still you have a fully live 3D document that you can dimension and annotate as you wish.
David Maudlin
Barry:
Your solution is fine if he can use Hidden Line, but not for Wireframe.
David
