Learn more
Measuring slab Perimeter
Did a search and surprisingly nothing though I thought this was covered before. But anyway, does anybody know if it's possible to measure a slab perimeter (or a couple of walls for that matter)? I tried the zone tool hoping (remembering something), but still nothing.
Ideas would be greatly appreciated (another job left for the very last minute).
6 Replies 6
Djordje
Element info, basic Calculations.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Have you tried WINDOWS menu > FLOATING PALETTES > SHOW ELEMENT INFORMATION
WoW... THANKS!!!
It only works for slabs right? Why not fills also? It'd be easier... but at least it works. Thanks again.
Sergio wrote:
WoW... THANKS!!!
Should work for anything.
I meant that it doesn't give you the perimeter of fills.
Thanks again for the help guys. I'd heard about this... "window", but I dodn't use it much (or at all) and lost it...
Sergio wrote:
I meant that it doesn't give you the perimeter of fills.(
Sure it does (the Element Information that is).
Its just called "Circumference" rather than "Perimeter".
