We value your input!
Mesh Showing wire frame
I drew this mesh having the model showing green grass and brown earth colour. I then copy and pasted this file to work on it further. In the new file the mesh is showing correctly, but in the original file - the mesh is showing as a wire frame. I have compared the settings in the mesh in both files are they are the same - but display differently. The building I have drawn doesn't show in a wire frame - just the mesh.
I have even tried to delete the mesh and copy and paste the new mesh into the old one - but it still shows as a wireframe.
I closed the archicad file and re-opened it - and still get the same result.
Has the layer been set as wire frame in the layer settings?
Hi Yes- thank you! this was what was wrong. I must have clicked it by accident!
