2004-09-08 06:11 PM - last edited on 2023-05-25 05:17 PM by Rubia Torres
2004-09-08 06:39 PM
2004-09-08 06:51 PM
tprokop wrote:Thanks,
Would be a nice ability to have.
2004-09-08 07:00 PM
2004-09-08 10:30 PM
2004-09-08 11:21 PM
Mark wrote:Wow what a TIP, my wish list was answered so immediately!! This should go on Tip & Tricks section. Trick is to edit one elevation on plan to a reference elevation and the drag/copy.
This has always been a must have feature for site plans. I noticed if you place more elev dims you will have to set this setting for each, so set one and copy.
2005-01-13 03:20 PM
2005-01-13 05:51 PM
You can use the reference levels in the elevation dimension!! I am not sure this is what you are looking for but if so, Select the label of an elevation dimension you have already placed ( with gravity to mesh or roof or whatever). You can select the label seperatly from the actual marker.What I would like to see on the wish list is the ability to chose the reference level prior to placing the "elevation dimension". In the current state you need to select each individual text block, which to my knowledge, can't be done with find and select. It also makes discovering this valuable feature next to impossible unless you get it from a group such as this.
