Mesh visibility
Hi, is there some tips how to get know that mesh will be or not visible in 3D ?
For example when I'm bendig too much I can't see mesh and if I I reduce bending it's gonna show in 3D.
Also this happen when I have some holes in mesh.
Do you know whats the right doing it to avoid it
Thanks 🙂
AC 7 - 27 SWE
iMac (Retina 5K, 27-inch, 2020),
3,6 GHz 10-Core intel Core i9, 64 GB 2667 MHz DDR4, AMD Radeon Pro 5700 XT 16 GB
David Maudlin
Vojtech Slavik:
What is probably happening is that the straight edge is crossing the arc near the nodes at the top and bottom of your shape. This creates a self-intersecting polygon that is impossible physically, so cannot be shown in 3D. Sometimes this can be seen by zooming in very close at the node.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
7 REPLIES 7
Hi Vojtech,
It may be some kind of bug related to micro gaps between coincident arcs.
I can see that there is a node in the middle of an Arc on the bottom one.
Check it the Arcs are really coincident (Curve and Nodes).
Hope this helps.
David Maudlin
Vojtech Slavik:
I don't think there is micro gap, there is must be some limit how thin can be mash or something.
This is example but if I have more complicated ground sometimes is very hard to find which "corner" is doing this problem
Braza wrote:
Hi Vojtech,
Hope this helps.
AC 7 - 27 SWE
It's definitely this but is there some way how to avoid it... because this information is not visible in 2D
David wrote:
Vojtech Slavik:
AC 7 - 27 SWE
Yes. David is correct.
It looks like a, lets say, limitation for the Mesh geometry. As I tested with Slabs and it works fine.
If using a Slab is not an option, as a workaround: Create node in the arc segment, right next to the point of inflection. Then convert the tiny arc segment to a straight one. This would do the trick.
Another solution, is to create a single pavement Mesh that covers also the lawn. Then do a SEO operation to cut the lawn from the pavement.
Hope this helps.
Ok, I understand.
Thanks
AC 7 - 27 SWE
Lingwisyer
Guru
I usually end up chamfering the points of meshes that are like that. It prevents any degen issues and is purely cosmetic, in my case anyway.
Ling.
