Michel Rojkind style
how can i model the irregular curve in archicad, i can model regular curved but this type which does not end where it start is giving me difficulty.
30 Replies 30
kliment wrote:
I haven't noticed a signifficant delay in 3D form generation due to Custom profiles. SEOs are the usual suspects.
If you have a lot of complex beams (thousands of them) and their layer has the same intersection priority as the walls, slabs and meshes this can slow things down considerably. I've run into this on large structural models. Of course this is because the beams essentially perform automatic SEOs on the other elements.
