Michel Rojkind style
how can i model the irregular curve in archicad, i can model regular curved but this type which does not end where it start is giving me difficulty.
30 REPLIES 30
Eduardo Rolon
AFAIK it was… There is nothing in that project that precludes the use of AC. Obviously Matthew is the correct person to answer.
Apple's Profile on Rojkind,
http://www.apple.com/pro/profiles/rojkind/index.html
He also uses Maya FWIT.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
On the other Nestlé project.
http://www.archdaily.com/19582/nestle-application-group-queretaro-rojkind-arquitectos/
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
AC 14 levels.
As with anything I could be wrong and none of this was done with AC.
AC29 US/INT -> AC08
another Moderator
Speaking about storey level marker heads, are there any black arrow-type markers to download ?
In AC there is only one type and that is the quaterly divided circle.
Here the usual standard si the arrow-type marker.
Eduardo Rolon
The ones in the Dim Settings do not work or are you referring to the automatic ones in the Section/Elevation Tools?
AC29 US/INT -> AC08
another Moderator
Yes, i`m referring to the automatic ones in the Section settings
Coty82 wrote:
Matthew wrote:
I worked with Michel on the Nestlé project.
Maybe this has been answered before, but since you`v worked on the project can you tell wich program was used? Was it Archicad at all?
As far as I know Michel uses ArchiCAD on all his projects.
Hello, could someone explain how AC does 'sphere segmetation' as showed in the picture? I need help on that one.
I was dedicating post to the picture ejrolon posted, not to the original project, but yes, that is what I am looking for. Creating those kind od wall, which are curved as a part of the sphere?
I don't know for sure on this one but I would use spherical library parts and SEOs. At least for the preliminary modeling anyway.
