‎2010-04-29 11:04 AM
‎2010-11-26 10:09 PM
Matthew wrote:I thought about that also, but it looks like you can't substract a sphere from a wall object. At least I couldn't menaged to do it. And even if I could do it, how to make those sphere parts to fill the cutted gaps?WhiteMan wrote:I don't know for sure on this one but I would use spherical library parts and SEOs. At least for the preliminary modeling anyway.ejrolon wrote:Hello, could someone explain how AC does 'sphere segmetation' as showed in the picture? I need help on that one.
On the other Nestlé project.
http://www.archdaily.com/19582/nestle-application-group-queretaro-rojkind-arquitectos/
‎2010-11-27 07:30 AM
WhiteMan wrote:If you use the sphere object in the library it should be a solid that will work for SEOs. The details of the order and pattern of the elements and their SEOs might be a bit complex depending on the desired result, but I don't see any reason it can't work.Matthew wrote:I thought about that also, but it looks like you can't substract a sphere from a wall object. At least I couldn't menaged to do it. And even if I could do it, how to make those sphere parts to fill the cutted gaps?WhiteMan wrote:I don't know for sure on this one but I would use spherical library parts and SEOs. At least for the preliminary modeling anyway.
‎2010-11-27 11:32 AM
‎2010-11-29 01:29 PM
‎2010-11-29 05:52 PM
‎2010-11-30 08:48 AM
kliment wrote:That's pretty much how Michel did the red house.
I did this in 2005, before Complex profile. The picture pretty much explains the process - modeled with slabs, saved as objects, and some SEOs.
‎2010-11-30 08:51 AM
WhiteMan wrote:I don't find them too slow unless I have thousands of them and forget to set the intersection priorities properly. What do you mean by viewport?
wow, realy nice work there...
But complex profiles are making things easier to model..
Only thing is that they slooooooooooowwww down AC a lot, viewport mostly. Any idea how to speed up working in viewport?
‎2010-11-30 03:41 PM
‎2010-12-06 08:40 AM
‎2010-12-06 06:09 PM
