2004-10-07
07:48 PM
2023-05-26
03:21 PM
Rubia Torres
2004-10-07 08:21 PM
2004-10-07 09:17 PM
2004-10-07 09:29 PM
Brad wrote:Could be. I assume you've checked all the settings in your workspace.
I did that and it showed up, but as soon as I switch back to mine it disappears again. Am I going to have to create my nifty workspace from scratch again?
2004-10-07 10:06 PM
2004-10-07 10:20 PM
Brad wrote:Actually, it does show, Brad ... but your screen resolution has to be set high enough, as the position in that default scheme is toward the lower right of the screen when the screen height is 1024 pixels (say a 1280 x 1024 resolution). If you have your res set to 1024 x 768, you are correct, the palette cannot be seen.
Yes I have. In the process of trying to reset my workspace I have dicovered that the US standard paleette scheme 9 does not show the 3d Navigation palette. I based my custom layout on it. I guess I'll have to find one that works.
2004-10-07 10:34 PM
