Missing Fill Consolidation Command
How do I add the fill consolidation command into the "edit" drop down menu under "reshape"? Not sure why it isn't there already.
Can anyone help?
Thanks,
Mary
If you are using the Standard Profile 11 then it should be there.
If not, go to the Menus page in the Work Environment dialog and in the list of field select All commands in alphabetical order. You will find Fill Consolidation in the list.
